I'm putting an adjustable RC trackbar on my comanche soon, when I lift it to 6.5". now this is kinda a newb question, but what size HEIM joint should fit, and any opinions on where to get it? I don't want to use a TRE, and I've got a nice heavy duty "drop" bracket that I will use to weld the heim mounts onto.
-Pat
Does it not come with a joint? What side are the threads in the bar? Check into that, then look at what heim will thread into it.
AARON
it's "used" from my 89 pioneer...provided that what TNT does doesn't involve that trackbar. it's got a TRE, and is a Rough Country brand. I don't trust the TRE at 6.5" of lift, so i'm going HEIM.
You'll probably get both track bars, the RE and the RC.
:brows:
call me when you get to work on stuff tomorrow...i'll come help so we can get that xj outta the shop, and the mj in there. :P wanna tear into your axles first?...
