88JeepManche Posted February 20, 2008 Share Posted February 20, 2008 Ok so all my parts are in for the lift. What all needs disconnected to lower the axle enough to let the spring have enough room to put the spacer in? Basically i want to do this with out a spring compressor. I know the sway bar and UCA's need unbolted. Do the LCA's? Anything else i am forgetting? Link to comment Share on other sites More sharing options...
89eliminator Posted February 20, 2008 Share Posted February 20, 2008 shocks, caliper (make sure that its supported after you take it off, don't let it dangle). if i remember correctly, i put in my 2in spacers with the lowers and uppers still attached. just jack up the truck high, put jackstands under the frame side lower control arm mount and lower the jack. Link to comment Share on other sites More sharing options...
88JeepManche Posted February 20, 2008 Author Share Posted February 20, 2008 Thanks. Link to comment Share on other sites More sharing options...
mjeff87 Posted February 20, 2008 Share Posted February 20, 2008 sway bar links too....and if you don't get enough droop that way, use a bottle jack on top of the axle to push it down furthur and hold it in place while you slip the spring out/in. I've got a pic somewhere....lemme see if I can find it so you can see what I'm talking about. Jeff edit: Image Not Found Link to comment Share on other sites More sharing options...
