maddzz1 Posted February 14, 2008 Posted February 14, 2008 I noticed a few weeks back that I needed a new radiator. This one is all rotted away but I was hoping it would survive till warmer weather. Today I get to work and anti-freeze all over the ground. The fins in the radiator are all missing. The idiot light never came on so I don't think it actually overheated (This is why I need to swap a cluster with gauges). Think if I put some antifreeze in I can drive it home?
BLHTAZ Posted February 14, 2008 Posted February 14, 2008 If you don't have to go far, you are in cold weather and it is not pouring out as fast as you put it in...you might make it. That is a big risk, but the weather/temp may be in your favor here.
maddzz1 Posted February 14, 2008 Author Posted February 14, 2008 Its only somewhere around 10 miles. I will see what happens when I add the coolant. If it stays in I will try it. If it is leaking I will have it towed. Thanks
