Whats this harness? with pic... =)
you have 2wd?
it's the connector to your center console lights (the ones for the 4wd indicator)
Yeah 2wd.. Cool I knew someone knew what it was!! So it goes where?? Is it a power supply in line with dash lights?? So it provides power with lights on right?? Or am I missing something, other then a transfercase.??.
you have 2wd?
it's got power to it right now, just needs the small extension/light harness that goes to the center console.
you have 2wd?
Sweet. At least I know I have a power source if I ever needed to tap into!! jamminz.gif
Thanks bro
no that'd be a bad place to get power. the console light is controlled by the headlight switch and is on the circuit with the dimmer so you could mess stuff up by not sending it full voltage.
That was my first thought.. Well might be able to use it as a dimming interior light.... or something..
Thats too bad cause I was thinkin about making it a aux power outlet for my phone..
