Twisty Posted February 2, 2008 Posted February 2, 2008 I don't keep my tire under the bed, but my friend does. Neither of us has any idea which tool to use to un-wind the cable. Can anyone take a quick snap shot of what it looks like to see if we have it? Thanks.
Geonovast Posted February 2, 2008 Posted February 2, 2008 Isn't it just held up by a ginormous wing nut?
summerinmaine Posted February 2, 2008 Posted February 2, 2008 I don't keep my tire under the bed, but my friend does. Neither of us has any idea which tool to use to un-wind the cable. Can anyone take a quick snap shot of what it looks like to see if we have it? Thanks. I just use the crank handle from the factory jack.
summerinmaine Posted February 2, 2008 Posted February 2, 2008 Isn't it just held up by a ginormous wing nut? Not originally. It's a cable lift that will wind down to lower the tire to the ground.
WahooSteeler Posted February 2, 2008 Posted February 2, 2008 your jack assembly should be 3 pieces: the jack; a thick, folding lug nut wrench; and a long, skinny folding jack crank handle. the crank handle, as noted, is what you insert in to the tube to crank down the spare.
Twisty Posted February 2, 2008 Author Posted February 2, 2008 your jack assembly should be 3 pieces: the jack; a thick, folding lug nut wrench; and a long, skinny folding jack crank handle. the crank handle, as noted, is what you insert in to the tube to crank down the spare. Thats what I suspected. Thanks for the help guys!
HOrnbrod Posted February 3, 2008 Posted February 3, 2008 Instead of digging out the jack handle every time I just ground down the socket end of an old rusty 3/8" drive speed handle I had laying around (not the one pictured :D ) to something approximating a blunt flat head screw driver and use it to lower and retract the spare. Works great. Image Not Found
WahooSteeler Posted February 3, 2008 Posted February 3, 2008 I'm sure it's chrome like the one pictured! :laughin:
HOrnbrod Posted February 3, 2008 Posted February 3, 2008 I'm sure it's chrome like the one pictured! :laughin: :eek: :eek: I could never grind on anything w. perfectly good chrome plating! :cheers:
