maddzz1 Posted January 19, 2008 Share Posted January 19, 2008 Would putting a little higher lift in back help with the driveshaft angle? Like 4" leafs with a 3.5" lift up front? Does higher in the back affect braking or steering? Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 19, 2008 Share Posted January 19, 2008 i don't think a higher rear end lift will do much. as for steering yes it will. when turning ar higher speeds there will be more body roll, braking will be less effective because less weight will be on the rear as you lift it higher then the front Link to comment Share on other sites More sharing options...
Pete M Posted January 19, 2008 Share Posted January 19, 2008 There shouldn't be any problems with driveshaft angles on a 4 inch lift. :thumbsup: Link to comment Share on other sites More sharing options...
