ratrapp Posted 3 hours ago Share Posted 3 hours ago did some maintenance on my nephews 86 today such as replacing the harmonic balancer that came apart and when i went to replace the headlight switch i found the connector had melted which really wasnt a surprise.ive looked my normal avenues but i havent found a replacement for the connector.does anybody know of a good source for one?thanks Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted 2 hours ago Share Posted 2 hours ago Can't answer but as a related comment, you might want to install the headlight rewire harness to make sure it doesn't melt again or worse. See this thread for some additional details. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted 1 hour ago Share Posted 1 hour ago I guess if you cannot get a replacement you could get some of these and attach the wires one at a time. Clearly not a preferred solution, but in a pinch. I see some 90 degree ones on ebay too that would probably work better in this case. Just a thought, hopefully someone can identify the actual connector. or https://www.ebay.com/itm/127679278912?_skw=crimp+one+wire+end+female+blade+connector&itmmeta=01KMTSW5C8YATP8X0HVYCH7YHV&hash=item1dba472f40:g:vV8AAeSwbmhpjFnh&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xB2%2FlyiKsG7kSgCKJHLqhIWNgXL8AHcxnYz4BdMxUldxxLwvFO955orUvxnLZlGw5aSXrfh6TwMmIa3LCBvzTwkV%2BxDCYdHP9cAiRW8Dy1bKeRhr%2BkrRQfF3JclKwVLL4s5FdDei%2F6%2B4%2FCjwMMlB412R%2B7N%2Bx4lr%2B6%2BEJAYvP7UsL9gVkC%2BMY7445xE%2FSXcn%2FSO6SGl7jQo%2F4mhVCEkjGzN6xCWxOpPpyAW8HSXWKbPAKC6rwEPWGmm0mAlV5aQy%2BBpUYmRMnz%2BRi0rvwMrU1ugi6Y2gOIY%2FqHpumUtxFSSYlcr0O7IvXm91S9uug6V3Y0%3D|tkp%3ABk9SR7DW8NmmZw Link to comment Share on other sites More sharing options...
