jpnjake Posted March 23 Share Posted March 23 I’m running into this issue while replacing my axle seals and installing new axle bearings, I pressed off my old bearings and now that I have the new ones on with the new seals I have endplay (in and out) about 10 thousandths on the drivers side only I never noticed any endplay before I changed my bearings I’m wondering if I should put a shim behind the race on the drivers side to take up the space when I had everything apart the new and old bearings/seals measured the same just wondering if anyone else has ran into this? Link to comment Share on other sites More sharing options...
jpnjake Posted Wednesday at 09:21 PM Author Share Posted Wednesday at 09:21 PM Bump this is still racking my brain I just compared it to my chief and it has next to no end play was able to get a real measurement on my current Endplay and it’s 30 thousandths and it’s on both sides, passenger side needs you to pull hard but has the same amount of play Link to comment Share on other sites More sharing options...
pizzaman09 Posted Thursday at 09:58 PM Share Posted Thursday at 09:58 PM That is strange. What brand bearings did you go with? I just did SKF bearings on my D44 and have no end play. Link to comment Share on other sites More sharing options...
