1989 Jeep Commanche
4.0 Renix / AW4 / 4wd / Short bed
Previous owner said it was a one owner vehicle - gentleman died and his wife stored it for a while; seller purchased in 2023 as a family friend. Odometer read 25,743 when purchased and seller guaranteed that was legitimate. Currently having the tranny worked on so haven't been able to dig into it much but haven't seen anything to indicate mileage is false.
BODY: JL61
BUILD: 06/14/89
SELLING DEALER: WESTSIDE-MARRERO JEEP-EAGLE INC
MARRERO, LA
*X2 DESCRIPTION NOT AVAILABLE -SA CHARCOAL BAYP 105 AMP ALTERNATOR
BCYP 95 AMP BATTERY CBAP STRAIGHT BACK BENCH SEAT DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS
DHTP SHIFT-ON-THE-FLY,P/TIME T/CASE EAAC ALL ENGINES EAFC
ERB 4.0L I6 MPI ENGINE GRVP LEFT MANUAL MIRROR HAA AIR CONDITIONING
PA2
Sterling Metallic
RAAC ALL RADIO EQUIPPED VEHICLES RCAP
SBAA POWER STEERING TAAC ALL TIRES TNCA P195/65R15 BSW AS TOURING TIRES
YGEA 5 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z66P LEFT FRONT GROUP XV
Z85P RIGHT FRONT SPRING GROUP XIV 5ALA
APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES BJAS DESCRIPTION NOT AVAILABLE
BKPS 10X2.5 REAR DRUM BRAKES CKJS BLACK VINYL FLOOR COVERING CSRS DO NOT USE - SEE CLASS JV
DGSS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHAS LOCK-UP TORQUE CONVERTER DHNS COMMAND-TRAC PART TIME 4WD SYSTEM
DJHS 230MM FRONT AXLE DMDS 3.55 REAR AXLE RATIO DRJS DANA 35 REAR AXLE
GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS
GEHS FIXED DOOR VENT GLASS GNAS REAR VIEW DAY/NIGHT MIRROR GUAS OPEN
JAAS INSTRUMENT PANEL JAZS DO NOT USE - SEE JP, KA CLASSES JBFS INSTRUMENT PANEL BLACK BEZEL
JCAS SPEED GRADUATION-MILES JKBS   KDAS STRIPE/BADGE/MOLDING/COLOR
K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS SEAT BELT ALERT-DRIVER SEAT ONLY LBCS GLOVE BOX LAMP
LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER
MFFS BLACK GRILLE MHBS FENDER FLARES MMCS
MMGS BELT MOLDINGS MMJS MOLDED-IN-COLOR FENDER FLARES NAAS FEDERAL EMISSIONS
NBAS UNDERGROUND CALIBRATION NBKS SELECTIVE CATALYTIC REDUCTION - WITH NDAS CATALYTIC CONVERTER
NF2S 18 GALLON FUEL TANK QA2S
Sterling Metallic
RACS OPEN
SCBS STEERING WHEEL SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS
TADS TIRES TBCS COMPACT SPARE TIRE TBMS TIRE CARRIER WINCH
WJKS 15X6.0 STYLED STEEL WHEELS WMCS OPEN XBSS PICKUP BOX
XFAS -35F PROTECTION ANTI-FREEZE YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z5AS GVW/PAYLOAD RATING
1AAS U.S. DEALER RETAIL 165S ZONE 65-NEW ORLEANS
  • fiatslug87 changed the title to 1J7FJ26L2Khttps://comancheclub.com/topic/75665-1j7fj26l2kl639693/L639693
  • fiatslug87 changed the title to 1J7FJ26L2KL639693
