coheed Posted September 13, 2025 Share Posted September 13, 2025 So, in swapping my 2.8 for a 3.4 I'm also getting rid of the AX5, NP207, and clutch pedal/master cylinder. I know that the bellhousings are the same between external and internal and that the clutch fork is different on the 84-86. Are there any other differences? And what's the value of said package? I have no clue how many miles are on them, the truck had at least 320k when I got it (the speedo cable was unhooked for who knows how long before I got it) and I've added 30k. Is the clutch fork the only really valuable bit of this? There's not a single AX5 on Facebook within a hundred miles of me to get an idea of price and Jeeps get picked clean within hours at local yards, so I know there's a demand. The only one on craigslist is an internal slave 300 miles away, and they're asking $250. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 13, 2025 Share Posted September 13, 2025 An ideal upgrade and easy bolt in for 87-90 2.5Ls. Hell might be able to go up $100 just because it’s got everything to do the swap. If I had money and a way to get both of them to me I absolutely would. I want to see if the 207 housing is the same size as the 229. Link to comment Share on other sites More sharing options...
coheed Posted September 14, 2025 Author Share Posted September 14, 2025 Well if anyone was using it to do a conversion on a 87 or later they'd have to get the later style master cylinder, but that's fairly cheap in the scheme of things. I could've answered if the 229 was bigger a few months ago if I knew it was a question in need of an answer. I sold the 229 I had on hand a while back. I don't remember it being substantially larger than either the 207 or the 242. It was heavier than 207 though. Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 14, 2025 Share Posted September 14, 2025 Yeah the 229 has been a question for sometime in my head but didn’t think anyone here would have both. Or a 207 near me to figure it out. I have this crazy idea to do some internal swapping, mostly the clutch pack diff in the case and the rear housing to fit such and make a 207/229 hybrid to fit behind a manual transmission since the 228/9 can only be found behind an auto on the XJ/MJ. Link to comment Share on other sites More sharing options...
