North Run Posted Friday at 09:06 PM Share Posted Friday at 09:06 PM So I've had my Comanche off the road since 2013. Started it up and dove it around the storage yards annually. Until the pandemic I never had an issue. The new owners felt the need to siphon my full tank of fuel. So when I went to pick it up last summer it was no go. Had to winch it onto and off the trailer to bring it home. Due to a hip issue it's been parked and neglected since. Now I want to put it back on the road. It gets better fuel economy and funner to drive them my 2500HD. It'll crank all day long but not fire. Lots of spark, fuel pressure at the TBI, not sure how much. I know I replaced the fuel pump back in 2011 or 2012. I pulled the fuel filter and when I turn the key, it only cycles for maybe 3 seconds. Having not driven or worked on my baby since 2012, I can't remember if that is normal. I'm at the point of dropping the tank and testing and inspecting. The last 3 days have convinced me the world has indeed moved on since 2012, lol. 3 days to get in a fuel filter, & distributor cap. Amazingly they still had spark plugs and a rotor cap. I foresee a trip into the closest city tomorrow morning and the closest pick n pull. So long rambling story aside, is my pump running for 2-3 seconds normal? I wish I had not lent out my boroscope, it never came back :(, I know the tank was almost factory new when I replaced the pump the last time. Keeping a fuel tank completely full or completely empty makes a difference. Link to comment Share on other sites More sharing options...
North Run Posted Friday at 09:15 PM Author Share Posted Friday at 09:15 PM I forgot to mention, when I add fuel directly to the throttle body, it will start and run until I run out of added fuel. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Friday at 11:59 PM Share Posted Friday at 11:59 PM Sounds like the injector isn’t pulsing. has the pump been tested? Link to comment Share on other sites More sharing options...
North Run Posted 7 hours ago Author Share Posted 7 hours ago Wish I would have taken a picture of the injector when I pulled it out. Judging by the amount of corrosion I'm going to be dropping the fuel tank and cleaning. So I can get a new fuel pump if needed within a few days for $110. Sadly the injector is 1 week out and $472 unless someone knows a better deal in Western Canada? Link to comment Share on other sites More sharing options...
89 MJ Posted 7 hours ago Share Posted 7 hours ago You might be able to clean the injector that you've got. Link to comment Share on other sites More sharing options...
eaglescout526 Posted 5 hours ago Share Posted 5 hours ago I second getting the injector cleaned. Cheaper than the new one. Link to comment Share on other sites More sharing options...
