James92 Posted June 4 Share Posted June 4 My odometer works for the first few miles when you start the truck, then stops counting. It varies, but sometimes it'll work for 3 miles and other times for 20 miles. The speedometer and tach work fine. The trip odometer tries to turn, but ultimately doesn't get anywhere. Any ideas? I havent taken the cluster out yet, just trying to get some ideas of what to look for. Thanks! Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 4 Share Posted June 4 It sure sounds like a worn out gear or something in the odometer itself, particularly if your speedometer works fine. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted June 11 Share Posted June 11 I had a similar scenario in an odometer in my car, the "works for the first few miles" issue, and for me it turned out to be a stepper motor in the odometer that was bad and quit as soon as it warmed up. I don't know what is in the MJ Odometer, so this might not apply, but it was my issue and a motor swap fixed the problem. Link to comment Share on other sites More sharing options...
James92 Posted June 13 Author Share Posted June 13 On 6/4/2025 at 5:09 AM, pizzaman09 said: It sure sounds like a worn out gear or something in the odometer itself, particularly if your speedometer works fine. Ah, thanks for the suggestion. I'll have to do some digging. On 6/11/2025 at 4:42 AM, AnotherOldJeepGuy said: I had a similar scenario in an odometer in my car, the "works for the first few miles" issue, and for me it turned out to be a stepper motor in the odometer that was bad and quit as soon as it warmed up. I don't know what is in the MJ Odometer, so this might not apply, but it was my issue and a motor swap fixed the problem. Wow, that's an interesting idea. I'll have to dig into it. Thanks! Link to comment Share on other sites More sharing options...
