golddigger Posted June 1, 2025 Share Posted June 1, 2025 I have a 88 4.0 which runs pretty good except when initial startup when it goes into open loop then idle will drop way down stumble back up then start to surge slightly any suggestions what i could be missing John Link to comment Share on other sites More sharing options...
Ωhm Posted June 1, 2025 Share Posted June 1, 2025 With ENGINE RUNNING, check for Battery Voltage on D2_9 (O2 Heater Circuit). Link to comment Share on other sites More sharing options...
golddigger Posted June 2, 2025 Author Share Posted June 2, 2025 thank you OHM what should i be seeing on a good circuit? John Link to comment Share on other sites More sharing options...
Ωhm Posted June 2, 2025 Share Posted June 2, 2025 10 hours ago, golddigger said: what should i be seeing on a good circuit? Battery Voltage with ENGINE RUNNING. This is a quick test. If GOOD, need to check O2S heater on the component itself. Disconnect C229 and on the component side connector check for resistance between pins C229_A and C229_B. Looking for ≈6 Ω's. If TRUE, circuit is GOOD. Note: This view is harness side. Link to comment Share on other sites More sharing options...
87MJTIM Posted June 2, 2025 Share Posted June 2, 2025 I'll throw my 2¢ in - have you checked for vacuum leaks? Mine was idling rough - 800 down to 500 rpms - with STFT down to 0. It felt like it would cut out at any second. I had a cracked vacuum line from the MAP to the TB. Fixed this and the idle is better. However, STFT is still low - 30-50. Link to comment Share on other sites More sharing options...
