1J7FT36L6LL229268
AnotherOldJeepGuy
BODY: TL61
BUILD: 03/12/90
SELLING DEALER: DAVID MCDAVID JEEP EAGLE
PLANO, TX
*E1 CLOTH BENCH SEAT -SA CHARCOAL ALM
ARL   BAYP 105 AMP ALTERNATOR BCYP 95 AMP BATTERY
CBAP STRAIGHT BACK BENCH SEAT CKAP CARPET DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS
DHTP SHIFT-ON-THE-FLY,P/TIME T/CASE ERB 4.0L I6 MPI ENGINE GFDA REAR SLIDING WINDOW
GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR GTZA MANUAL REMOTE MIRRORS
HAA AIR CONDITIONING JHAA VAR INTERMITTENT WINDSHIELD WIPERS JJAP CIGAR LIGHTER
KKEP DESCRIPTION NOT AVAILABLE K2XP STRIPE/BADGE/MOLDING/COLOR MBJP BLACK BUMPER
MDAP FRONT LICENSE PLATE BRACKET MFGP HEADLAMP BEZEL MHAP BLACK WINDSHIELD MOLDINGS
MMKP   NHM SPEED CONTROL PX8
RAAC ALL RADIO EQUIPPED VEHICLES RAF OPEN RCDP 4 SPEAKERS
SBAA POWER STEERING SCEP STEERING WHEEL SUA TILT STEERING COLUMN
TAAC ALL TIRES TPFA P205/75R15 BSW ALL SEASON TIRES WJDP WHEELS
WLYC ALL STEEL WHEELS YGEA 5 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I
Z59P LEFT FRONT SPRING GROUP IX Z78P RIGHT FRONT SPRING GROUP VIII 5KMA
APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES CSRS DO NOT USE - SEE CLASS JV
DGSS 4-SPEED AUTOMATIC AW4 TRANSMISSION DMDS 3.55 REAR AXLE RATIO DRJS DANA 35 REAR AXLE
GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS
GEHS FIXED DOOR VENT GLASS GNAS REAR VIEW DAY/NIGHT MIRROR JAZS DO NOT USE - SEE JP, KA CLASSES
JCAS 85 MPH PRIMARY SPEEDOMETER K3XS STRIPE/BADGE/MOLDING/COLOR LBCS GLOVE BOX LAMP
LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER
MMCS   MMGS BELT MOLDINGS NAAS FEDERAL EMISSIONS
NBKS EVAP CONTROL SYSTEM NF2S 18 GALLON FUEL TANK QX8S
Black
SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBCS COMPACT SPARE TIRE
TBMS TIRE CARRIER WINCH XBSS PICKUP BOX YAAS BUILD TO U.S. MKT. SPECIFICATIONS
Z1AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 163S ZONE 63-DALLAS
  • 1 month later...
Installed new radio.  Kenwood KDC-X305.  Fits well but that is not a surprise since it is a 1U standard unit, and the one I had in there before (Blaupunkt San Jose MP41) was that also and I had already opened up the dash trim to allow the face-plate trim to fit.  The install was smooth because of the standard size, and because Crutchfield provides the necessary connection harness the mates to the Jeep harness so all the wiring gets done at the kitchen table instead of in the cab, and the Jeep harness is unmodified.  The Kenwood sounds good enough, but it is not the unit the Blaupunkt was.  The Blaupunkt sounded better, and the user interface was WAY better!  Sadly the 1994 purchased San Jose is no longer available and neither are spare parts.  I do actually have 3 of them, the original and two purchased off EBAY that didn't last.  I may actually try to make 1 good one out of the 3 I have, but I would not be holding my breath at successful radio repair!
Worth noting that when I installed the Blaupunkt in 1994 I also installed new front speakers and added the tweeters already mentioned in my OP.
