Ken Seymour Posted March 24, 2025 Share Posted March 24, 2025 Been a while. I'm working on the driver side door I bought. I am trying to remove the vent window. The body manual is awful when it comes to instructions to accomplish this. All three screws are out and the window and track are tilted back. I have the track pulled up but can't get it out the window slot. I did not pull the rubber wiper. The bottom track mount hits. Does it need to be off? Also want to put my original lock in the door so the right and left side match. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 24, 2025 Share Posted March 24, 2025 It should tilt back with every bolt removed and come out. If need to, you could unbolt the window glass, lower it gently to rest in the door and the wing window should come out by then. Link to comment Share on other sites More sharing options...
Pete M Posted March 24, 2025 Share Posted March 24, 2025 lean back to pull it most of the way out, then lean it forward to get that last bracket to clear. Link to comment Share on other sites More sharing options...
