Flizo Posted January 12, 2025 Share Posted January 12, 2025 Hello, I'm in the process of getting my Comanche back on the road and realized the turn signal mechanism is toast. It doesn't appear to be the actual stalk but something deep in the column. Is there something that could break and not allow the turn signals to activate? The high beams work but turn signals to click and the washer sometimes works. The whole thing is floppy. I attached a photo I can't tell if that's broken or just looks that way. Anybody know what part I would need and while I am in the column anything else I should change or check on while in there? Thanks Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 12, 2025 Share Posted January 12, 2025 Well there’s a couple things. There’s the whole turn signal switch assembly itself that could be broken or it could be something as simple as the arm that attaches to the stalk that moves the switch up or down to turn a signal on is not in alignment. Link to comment Share on other sites More sharing options...
Flizo Posted January 12, 2025 Author Share Posted January 12, 2025 Thanks for the reply, I guess I'll tear it apart and see what's what. The horn center cap for the wheel was off and the hazard switch is also broken so I suspect the previous owner was in there. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted January 12, 2025 Share Posted January 12, 2025 My turn signal stalk is a bit weak as well but still works. I don't know if that's normal or just wear from being 37 years old. Curious what you find. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted January 12, 2025 Share Posted January 12, 2025 It sounds like there might be a problem with the turn signal switch itself. The stalk doesn’t really do much. The switch is fairly cheap to replace, and you can even replace just the canceling springs if that’s all that’s wrong with it. you have to pull the steering wheel and take a few things apart to get to it. It’s a bit of a pain. Then you can do a visual inspection. One of the canceling springs was fatigued in mine, so it didn’t always click in going left, but a new pair of springs sorted that out. Link to comment Share on other sites More sharing options...
Flizo Posted January 12, 2025 Author Share Posted January 12, 2025 I just ordered the turn signal switch from rockauto and just need to grab a steering wheel puller to get to work once it arrives. Link to comment Share on other sites More sharing options...
Flizo Posted January 15, 2025 Author Share Posted January 15, 2025 Alright a big Thank you for bringing attention to the arm connected to the stalk and switch. That arm was not properly connected. It looks like the lock cylinder was changed at one point and whoever put it back together didn't know what they were doing. The steering wheel wasn't on tight and the lock ring wasn't even on. I properly attached the lever and now the turn signals work and the stalk is LESS floppy but still has a bit of play to it. Anyone know the name of the part that the stalk connects to? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 15, 2025 Share Posted January 15, 2025 The stalk plugs into the wiper switch. I wouldn’t worry about it being tight like a new car as even if you swap out the switch, it still pivots on a rod that goes into the upper housing of the column. Link to comment Share on other sites More sharing options...
