coheed Posted January 4, 2025 Share Posted January 4, 2025 Looks like Ironman4x4fab is going to make some shackle relocation brackets. I personally would buy a set because it's an automatic inch of lift and if you're running longer shackles you can make sure your shackle angle is correct, instead of extreme like some of the longer shackles tend to get. But they're saying they'll only fit short beds. I don't know if the distance from shackle hole to the last bumper mount hole is different from lwb to swb? I measured my lwb at 3 11/16ish. Could someone measure their swb to see how far off they are? Link to comment Share on other sites More sharing options...
gogmorgo Posted January 5, 2025 Share Posted January 5, 2025 They’re definitely different between long and short bed. On a short bed the shackle hangers are right at the back of the frame. Notice how in their photos it’s right underneath the bumper bracket instead of ahead of it like your long bed. There’s about six inches less frame behind the shackle mount on the shortbed, but the bumper brackets are the same. The bulge in the factory bumper bracket and the spacers used in the hitches exist to clear the shortbed shackle hanger… although the early bumper brackets didn’t all have the bulge because there were no early short beds so your ‘86 might just have flat bumper brackets, so in that case forget I said anything about that. Unless they expressly said they test fit them on a longbed and there’s no way it’ll work, it looks to me like all you’d need to do is drill the extra hole in the side and bottom of the frame. Maybe put a spacer under the side bolt to account for the bumper bracket not being there. The hangers themselves are the same between long and short and I’m pretty sure both frames are flat underneath in that whole area. Might be interesting fishing the nuts that deep into the longbed but it shouldn’t be impossible. Link to comment Share on other sites More sharing options...
coheed Posted January 8, 2025 Author Share Posted January 8, 2025 On 1/4/2025 at 7:12 PM, gogmorgo said: They’re definitely different between long and short bed. On a short bed the shackle hangers are right at the back of the frame. Notice how in their photos it’s right underneath the bumper bracket instead of ahead of it like your long bed. There’s about six inches less frame behind the shackle mount on the shortbed, but the bumper brackets are the same. The bulge in the factory bumper bracket and the spacers used in the hitches exist to clear the shortbed shackle hanger… although the early bumper brackets didn’t all have the bulge because there were no early short beds so your ‘86 might just have flat bumper brackets, so in that case forget I said anything about that. Unless they expressly said they test fit them on a longbed and there’s no way it’ll work, it looks to me like all you’d need to do is drill the extra hole in the side and bottom of the frame. Maybe put a spacer under the side bolt to account for the bumper bracket not being there. The hangers themselves are the same between long and short and I’m pretty sure both frames are flat underneath in that whole area. Might be interesting fishing the nuts that deep into the longbed but it shouldn’t be impossible. Yeah, both my truck and my trailer are 86s so they both had the flat brackets. I did buy an old Smittybilt tube rear bumper in a junkyard one time, so I do know of the bump you're talking about. In their Facebook comments they said they didn't have a long bed to test fit on, so I assume they weren't designed with those measurements into consideration at all like you're saying. But on the product page they say you have to drill to mount. So potentially drilling 2 instead of one to get them to fit isn't a huge deterrent. Recently I had to cut my bumper mount bolts off with an air hammer and fish some in to remount my bumper when I installed my krusty hitch. I used a 3/8 breaker bar that also doubles as an extension and used more extensions to get deeper into the frame as needed with some painters tape in the socket to hold the nut, so that also isn't a deterrent. I may pull the trigger on these since they are doing a limited run to gauge interest and set pricing this month, and they'll probably be more expensive afterwards. At the bottom of the page they say a long bed version is in development, but I asked them about a timeline and they didn't have one. For anyone interested in them here's the product page https://ironman4x4fab.com/collections/comanche-mj/products/mj-rear-shackle-relocation-brackets Link to comment Share on other sites More sharing options...
