1J7FT36L2KL512118
ZethC
1989 Jeep Comanche Pioneer
4.0 AW4 D44 SWB 2WD
Build Date 1-89
350k miles before I swapped the cluster
Currently in southern Iowa and it is my daily driver in the summer
Bought it bone stock. Owner before me had a fire start under the dash and basically trashed the harness, swapped in a 92 Jeep Cherokee drivetrain and wiring harness. now has a 4.0 HO aw4 np231 d35 front axle factory d44 rear. has a RC 4.5 inch lift, adjustable upper and lower control arms, and 33x12.5x15. Did alot of oem style upgrades such as all the woodgrain trim, factory clock, and actually cut down a factory xj overhead console reupholstered and installed it, plugged right in since my harness is from a 92 xj.
One thing I am curious about is the d44 rear end, is it factory or has someone swapped it in.
hopefully I did this correct first time poster long time listener😁
  • 4 weeks later...
BODY: TM61
BUILD: 01/26/89
SELLING DEALER: HALLMARK DODGE
ANTIOCH, TN
*E1 CLOTH BENCH SEAT -YY DESCRIPTION NOT AVAILABLE ADA LIGHT GROUP
ADH HEAVY DUTY ELECTRICAL GROUP AHL HEAVY DUTY INSULATION GROUP AHY
ALN BUMPER GROUP BA1P DESCRIPTION NOT AVAILABLE BCYP 95 AMP BATTERY
CBAP STRAIGHT BACK BENCH SEAT DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DHTP SHIFT-ON-THE-FLY,P/TIME T/CASE
DRKP REAR AXLE EAAC ALL ENGINES EAFC
ERB 4.0L I6 MPI ENGINE GFDA REAR SLIDING WINDOW GNBP DRIVER SIDE ILLUMINATED SUN VISOR
GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR GTZA MANUAL REMOTE MIRRORS
HAA AIR CONDITIONING HGAP HOOD INSULATION JHAA VAR INTERMITTENT WINDSHIELD WIPERS
LAJP HEADLAMPS ON WARNING CHIMES LBBP COURTESY LAMPS LBDP ASH TRAY LAMP
LBEP AMBIENT LIGHT LDHP U/HOOD, REMOVABLE/RECHARGEABLE LAMP LHDP HEADLAMP OFF TIME DELAY
LPEP CARGO LAMP NHBP AUXILIARY TRANSMISSION OIL COOLER NMCP HEAVY DUTY ENGINE COOLING
PY7 DESCRIPTION NOT AVAILABLE RAAC ALL RADIO EQUIPPED VEHICLES RABA OPEN
RCDP 4 SPEAKERS TAAC ALL TIRES TAEA TIRE SIZE:TBD
TBB FULL SIZE SPARE TIRE TMWA TIRES YGBA 1 ADDITIONAL GALLONS OF GAS
YGGA 9 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z59P LEFT FRONT SPRING GROUP IX
Z78P RIGHT FRONT SPRING GROUP VIII 5AMA JF/3450 VEHICLE FAMILY 5KNA METRO CARS OF DETROIT
APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES BJAS DESCRIPTION NOT AVAILABLE
BKPS 10X2.5 REAR DRUM BRAKES CKAS CARPET CSRS PASSENGER ASSIST HANDLES
DGSS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHAS LOCK-UP TORQUE CONVERTER DMDS 3.55 REAR AXLE RATIO
GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS
GEHS FIXED DOOR VENT GLASS GNAS REAR VIEW DAY/NIGHT MIRROR JAAS INSTRUMENT PANEL
JAZS DO NOT USE - SEE JP, KA CLASSES JBDS   JCAS 85 MPH PRIMARY SPEEDOMETER
JJAS CIGAR LIGHTER JKBS   KKFS DESCRIPTION NOT AVAILABLE
K2XS STRIPE/BADGE/MOLDING/COLOR K3YS   LAFS SEAT BELT ALERT-DRIVER SEAT ONLY
LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS
MBJS BLACK FRONT BUMPER MB1S BLACK FRONT BUMPER MFGS BODY COLOR HEADLAMP BEZELS
MHAS BLACK WINDSHIELD MOLDINGS MMCS   MMGS BELT MOLDINGS
MMKS   NAAS FEDERAL EMISSIONS NBAS UNDERGROUND CALIBRATION
NBKS EVAP CONTROL SYSTEM NDAS CATALYTIC CONVERTER NF2S 18 GALLON FUEL TANK
QY7S
Sand
SBAS POWER STEERING SCES STEERING WHEEL
SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBMS TIRE CARRIER WINCH
WJDS WHEELS XBSS PICKUP BOX XFAS -35F PROTECTION ANTI-FREEZE
YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z1AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL
164S ZONE 64-MEMPHIS
