llhat Posted October 23, 2024 Author Share Posted October 23, 2024 once i get to this I will update I send a sincere Thank you for all of your assistance Link to comment Share on other sites More sharing options...
llhat Posted November 4, 2024 Author Share Posted November 4, 2024 update now... been busy ... then recovering... Lift repair (replace 20 y.o. hydraulic hoses) it's been years since i have been up and down a 12ft ladder so much.... so today I replaced the Neutral Safety Switch on the AW4, with lift it was not "too" bad of a job. Mixed results... I do NOW have reverse lights, and no-start in 'gears', and start only in N or P ( did not have reverse lights initially) but.......... made zero difference in transmission "still" tries to start in probably 3rd gear with selector in D, and when i manually shift to 1, i get 1 was tired so walked away from it. I think next is to go back a few posts and Key ON C234 not connected to TCU Gearshift "1" position c234 D7-C8 voltage? Gearshift "D" position C234 D7-C9 voltage? tired today... will drop lower dash again tomorrow and test unless something else is suggested... i have since also installed new positive and negative battery leads and cleaned grounds. Link to comment Share on other sites More sharing options...
llhat Posted November 6, 2024 Author Share Posted November 6, 2024 On 10/23/2024 at 5:06 PM, Ωhm said: True. Seems like NSS needs some looking at. On 11/4/2024 at 3:24 PM, llhat said: update now... been busy ... then recovering... Lift repair (replace 20 y.o. hydraulic hoses) it's been years since i have been up and down a 12ft ladder so much.... so today I replaced the Neutral Safety Switch on the AW4, with lift it was not "too" bad of a job. Mixed results... I do NOW have reverse lights, and no-start in 'gears', and start only in N or P ( did not have reverse lights initially) but.......... made zero difference in transmission "still" tries to start in probably 3rd gear with selector in D, and when i manually shift to 1, i get 1 was tired so walked away from it. I think next is to go back a few posts and Key ON C234 not connected to TCU Gearshift "1" position c234 D7-C8 voltage? Gearshift "D" position C234 D7-C9 voltage? tired today... will drop lower dash again tomorrow and test unless something else is suggested... i have since also installed new positive and negative battery leads and cleaned grounds. Link to comment Share on other sites More sharing options...
llhat Posted November 15, 2024 Author Share Posted November 15, 2024 just a bump for any additional ideas.... Link to comment Share on other sites More sharing options...
llhat Posted November 30, 2024 Author Share Posted November 30, 2024 (edited) after going back and again checking the items suggested by OHM (thank you!) the only other thing left was a TCU I looked thru evilbay, and finally sourced a unit the seller indicated was working (he also offered a 'cheep' unit but stated "parts only). I communicated with them and he would not indicate 'that one' would be a good unit. Not the 'best' of $$$ deals, but.... (if anyone knows of a decent supplier let me know I may buy a spare) Item arrived 11/27 and today i installed, but before doing so re-checked voltages at C232, pins C8 and C9 I did get voltage per the shift position, and I had backup lights.. so the NSS replacement was also a positive, but now even with voltage at the pin with lever in D, no shift, no start in 1 I R&R the TCU with the sourced unit, buttoned it up and knocked on some wood. hoo ray! Have not given a long drive 'yet' but enough to know the vehicle starts moving in gear 1, and shifts on its own. Road was blocked by utility construction, so my drive was cut short, will give er a go a bit later today to test converter lockup I want to extend a BIG to OHM and others that responded to this thread. Hope to repay the favor one day. Edited November 30, 2024 by llhat add info Link to comment Share on other sites More sharing options...
Ωhm Posted November 30, 2024 Share Posted November 30, 2024 Link to comment Share on other sites More sharing options...
Jack p Posted October 12, 2025 Share Posted October 12, 2025 This seems like I am having a similar issue but slightly different. I have a 89 Renix Automatic with the AW4. My shifting problem consists of having to drive the jeep manually for a random amount of time until it is warm. After the first shift of the day it runs incredibly smooth. With the exception of randomly slipping out of gear. I’m constantly putting in and taking out my 10 fuse depending on whether or not the jeep wants to shift. Note the jeep shifts perfect with no hesitation manually. Which leads me to believe I have an electrical issue. But it also will shift after I have been driving for awhile and put the fuse back in. things I have done: replaced all 3 solenoids and changed fluid and filter(dex merc), cleaned and replaced all ground with the jeep cables kit, purchased a new(used) TCM. Cleaned inspected and sprayed all my electrical connectors, checked for voltage at the fuse which is good 12 volts. I'm beginning to think it could actually be a transmission problem. Even though it shifts perfectly fine manually. Or maybe something is messed up with the solenoid for 2nd gear? With the fuse in on a warm morning, first start of the day it will just high rev and never get out of first gear. Please someone steer me in another direction. Link to comment Share on other sites More sharing options...
Jack p Posted October 12, 2025 Share Posted October 12, 2025 Also wanted to mention I went digging into the old duct tape to see if I had any corrosion and the little metal resistor piece was snapped off. It seems like an unsafe hazard so I snipped the wires. Does anyone know what these two wires are for and why they are connected like this? Could this be adding to my issue? Link to comment Share on other sites More sharing options...
coolwind57 Posted November 13, 2025 Share Posted November 13, 2025 On 10/12/2025 at 1:10 AM, Jack p said: This seems like I am having a similar issue but slightly different. I have a 89 Renix Automatic with the AW4. My shifting problem consists of having to drive the jeep manually for a random amount of time until it is warm. After the first shift of the day it runs incredibly smooth. With the exception of randomly slipping out of gear. I’m constantly putting in and taking out my 10 fuse depending on whether or not the jeep wants to shift. Note the jeep shifts perfect with no hesitation manually. Which leads me to believe I have an electrical issue. But it also will shift after I have been driving for awhile and put the fuse back in. things I have done: replaced all 3 solenoids and changed fluid and filter(dex merc), cleaned and replaced all ground with the jeep cables kit, purchased a new(used) TCM. Cleaned inspected and sprayed all my electrical connectors, checked for voltage at the fuse which is good 12 volts. I'm beginning to think it could actually be a transmission problem. Even though it shifts perfectly fine manually. Or maybe something is messed up with the solenoid for 2nd gear? With the fuse in on a warm morning, first start of the day it will just high rev and never get out of first gear. Please someone steer me in another direction. Hey Jack, I had a similar situation. Went through seemingly everything before I found out that it was simply my Neutral Safety Switch (NSS). The crazy thing is this--I had replaced my NSS only 2-3 years ago. The NSS was at the bottom of my list of things to go through, and low and behold that was the issue. Try replacing yours. They're not so expensive. Good luck man if you haven't fixed yours already. Let us know if you got yours up and running. Link to comment Share on other sites More sharing options...
