fiddlermj Posted September 18, 2024 Share Posted September 18, 2024 So I found two differ gauge clusters for my 88 Automatic. Well the one i got thats full gauge 88 has no PRNDL clip wire. Well neither of em do. Ones differ speedometer cable but one has the right one. My question is…. I read somewhere if cable is not connected it won't drive? Is there a way to modify this….or DO i need the wire to show what gear I'm in? I mean…. Id LIKE to see the gear i am in…. But the one in dummy gauge rusted out and i rigged it…. So i still have to think what gear i am in….. orrrrrrrr does any body want a trade 😁 Link to comment Share on other sites More sharing options...
89 MJ Posted September 18, 2024 Share Posted September 18, 2024 I don’t think you need the gear indicator working for the truck to drive, but I may be wrong. You can carefully modify the cluster and make put the indicator in the full cluster. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted September 18, 2024 Share Posted September 18, 2024 You don’t need the cable to drive. It’s just an indicator. It clips to the column itself and just pulls the needle across when you shift. If the original cable broke, as long as you can find a way to attach that cable to the column, you can install the prndl indicator to a new cluster. Link to comment Share on other sites More sharing options...
fiddlermj Posted September 18, 2024 Author Share Posted September 18, 2024 Whew THANKS!!!!! Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted September 19, 2024 Share Posted September 19, 2024 I can confirm. My '89 has a busted indicator that won't shift with the gear. I can drive the truck just fine. Thing is, I don't know what my options are. I hear that the part to fix it is in a GM shift column. Link to comment Share on other sites More sharing options...
