Gradinen Posted May 23, 2024 Posted May 23, 2024 Hello, greetings from Sweden. I bought an old Comanche Laredo 88 which has been standing in a shed for 10+ years. I've done some replacements and so forth. Issue at hand: I raplaced ignition coils, spark plugs and took a test run. I parked it in my garage and a couple of days later I tried to start the car and there's no power at all. No power comes to the dashboard, starter or anything. Its completely dead. I've replaced + and - cables from the batteri, changed battery. And when I short the starter the starter runs. I'm not an expert mechanic and can't find the issue. Anyone been through something similar who knows which fuses to check and so forth? I'm terrible at reading electicral schematics but I'll do my best. I got a few tips to check the ignition switch?
Spinnakerblue89 Posted May 24, 2024 Posted May 24, 2024 As the above poster asks, what motor is in the truck? And you might have better input if you include year, engine, transmission in your sig so we can quick reference your model. And to clarify, are you stating that when you short the starter it itself cranks, but the motor does not turn over? Also, if you have not done so, please take the time to look at Cruiser54's Mostly Renix tips, particularly the grounds and other electrical tips.
Gradinen Posted May 24, 2024 Author Posted May 24, 2024 My bad. Its a 4.0L Automatic gearbox. 1988 Laredo. I just got the bright idea to check the Light switch for the headlights. That round pull thing. It worked. But nothing from the ignition switch works. Like radio, panels or windows etc.
Ωhm Posted May 24, 2024 Posted May 24, 2024 Using a voltmeter or 12vdc testlight (preferred) check for Battery_Voltage_(B+) on the following pins (use battery_negative terminal for ground): D1_5: B+ (Hot at all times) D1_6: At KEY ON only (B+ (Hot for 2-3 seconds)). During CRANK Hot at all times. D2_4: B+ (Hot during KEY ON and Hot during CRANK).
Gradinen Posted June 29, 2024 Author Posted June 29, 2024 Hai! sorry for late reply, we did as OHM Said. Non of the mentioned were hot or did give any signal.
Gradinen Posted June 29, 2024 Author Posted June 29, 2024 Hai! sorry for late reply, we did as OHM Said. Non of the mentioned were hot or did give any signal. we are tracing every cabel there is now, there is som funky builds in here…
Ωhm Posted June 29, 2024 Posted June 29, 2024 Need to look at your fusible links. Look for open circuits. Fusible links connect to the starter relay at the battery terminal bolt.
Gradinen Posted June 30, 2024 Author Posted June 30, 2024 Found it! The Cable for plus was gone. Might have found one that looked crisp… Now it runs! you truly are a Magician. Are there ”fuses” on the cable from the battery to this box? Or can i just replace it with a plain wire? Thanks again!
Ωhm Posted June 30, 2024 Posted June 30, 2024 Cable between battery positive and starter relay is 8-gauge wire, no fuse. Good to hear its up and running.
