Joseph V Posted April 28, 2024 Share Posted April 28, 2024 I I went thru the steps to adjust the TPS on my 88 Comanche Chief 4.0. My input voltage is not 5.0 volts, it is only 4.33. So using the ratio, the output should 0.736 volts. My TPS will only adjust to 0.54volts. I bought two different ones, one from O’Reilly and another from Advance Auto Parts. Both only adjusted to 0.17 volts. I put the original back in. The question is: is the low input causing the TPS to not be able to adjust or if the input voltage really doesn’t matter as long as the ratio is correct, then can anyone recommend a new TPS that will work? Link to comment Share on other sites More sharing options...
Ωhm Posted April 28, 2024 Share Posted April 28, 2024 Check and make sure the TPS wiper arm, is on the correct side of the throttle plate wiper. Sound like it's on the wrong side (0.17vdc). Link to comment Share on other sites More sharing options...
Joseph V Posted April 28, 2024 Author Share Posted April 28, 2024 It’s definitely on the correct side. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 29, 2024 Share Posted April 29, 2024 Have you completed Tips 1 and 3 on my website? are you using Tip 8 as a guideline for your TPS adjustment? Link to comment Share on other sites More sharing options...
Joseph V Posted April 29, 2024 Author Share Posted April 29, 2024 Yes, I cleaned all grounds and pulled ever connection I could find. I am using the information in your Tip number 8 to adjust the TPS. I’m just trying to understand why the original throttle position sensor can be adjusted from 0 to .55 but no further. And why the new ones will only go from 0 to .17 Also the low input voltage must indicate something? Link to comment Share on other sites More sharing options...
cruiser54 Posted April 29, 2024 Share Posted April 29, 2024 Perhaps your original TPS is bad and the replacements are also? How does it run at 54%? Link to comment Share on other sites More sharing options...
Joseph V Posted April 29, 2024 Author Share Posted April 29, 2024 I don’t understand what you mean by 54%, At 4.33 volts input voltage x 17%= .7361 volts. This is the reading I should be getting. I am only able to get 0.54 volts output. .54/.7361 = 73.61% of where it should be. Link to comment Share on other sites More sharing options...
Joseph V Posted April 29, 2024 Author Share Posted April 29, 2024 If you mean .54 volts, the truck runs pretty good except that when you first start it , it dies. Restart and it runs good. Sometimes when I let up on the gas, it will die. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 29, 2024 Share Posted April 29, 2024 Wanna try something? Is your throttle body clean? Open up the throttle plates a skosh and remember how far you turned the screw. Try 1/4 turn for fun. See what TPS reads and then drive it. Link to comment Share on other sites More sharing options...
Joseph V Posted May 1, 2024 Author Share Posted May 1, 2024 If you mean .54 volts, the truck runs pretty good except that when you first start it , it dies. Restart and it runs good. Sometimes when I let up on the gas, it will die. Link to comment Share on other sites More sharing options...
Joseph V Posted May 1, 2024 Author Share Posted May 1, 2024 Ok, I’ll give it a try and let you know. Thumbs crossed. ( did clean the throttle body, but I used some carburetor cleaner I had. I hope I didn’t mess it up.) Link to comment Share on other sites More sharing options...
cruiser54 Posted May 1, 2024 Share Posted May 1, 2024 You can't hurt the throttle body itself with carb cleaner. Link to comment Share on other sites More sharing options...
