Silverhawk1991 Posted March 27, 2024 Share Posted March 27, 2024 Does anyone have a solution for a rear sliding window that slides? I’ve tried adding foam around the edges, but no dice. Link to comment Share on other sites More sharing options...
89 MJ Posted March 27, 2024 Share Posted March 27, 2024 Is yours OEM (3 panes) or aftermarket CR Lawrence (4 panes)? I suspect that either your latch is rattling because something is bent or broken or that your felt window runs have worn out letting the glass rattle around. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 27, 2024 Share Posted March 27, 2024 1 hour ago, 89 MJ said: Is yours OEM (3 panes) or aftermarket CR Lawrence (4 panes)? I suspect that either your latch is rattling because something is bent or broken or that your felt window runs have worn out letting the glass rattle around. OEM. He has MJCARENA's MJ. Link to comment Share on other sites More sharing options...
89 MJ Posted March 27, 2024 Share Posted March 27, 2024 57 minutes ago, eaglescout526 said: OEM. He has MJCARENA's MJ. Gotcha. I knew he had MJCARENA’s old truck, I just couldn’t remember which slider he had. In that case, I’m going to guess that the center pane is loose in its channel. Link to comment Share on other sites More sharing options...
