Fredo Posted March 20, 2024 Share Posted March 20, 2024 just found some good rear speakers base. any one know what size of speaker they use? Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted March 20, 2024 Share Posted March 20, 2024 the stock rear speaker brackets are for 4x6 speakers. Boxyjeep makes 6in rear speaker brackets if you want to go bigger Link to comment Share on other sites More sharing options...
Fredo Posted March 20, 2024 Author Share Posted March 20, 2024 thank guy!!.. do you happen to know size of the front speakers? Link to comment Share on other sites More sharing options...
Fredo Posted March 20, 2024 Author Share Posted March 20, 2024 16 minutes ago, Salvagedcircuit said: the stock rear speaker brackets are for 4x6 speakers. Boxyjeep makes 6in rear speaker brackets if you want to go bigger 17 minutes ago, Salvagedcircuit said: the stock rear speaker brackets are for 4x6 speakers. Boxyjeep makes 6in rear speaker brackets if you want to go bigger thank guy!!.. do you happen to know size of the front speakers? Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 20, 2024 Share Posted March 20, 2024 5"x4" for the fronts. I believe. Or they might be 5x5. Link to comment Share on other sites More sharing options...
Fredo Posted March 20, 2024 Author Share Posted March 20, 2024 19 minutes ago, eaglescout526 said: 5"x4" for the fronts. I believe. Or they might be 5x5. thank you guy!! Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted March 20, 2024 Share Posted March 20, 2024 The stock front door speakers are 5.25in diameter speakers. Some people have successfully fit 6.5in speakers in the front doors but it's a tight fit and gets really close to the manual hand crank. Crutchfield is an excellent source of information on speaker sizes and types. Their prices are a bit high though. If you are missing the square plastic speaker nylon nut plugs they are auveco part# 13933 I purchased them from here and they were the same. These clips are used throughout the jeep. They are the same plastic screw inserts that hold the grill onto the front facia. GM used them a lot on 70-80s cars and AMC loved factory leftovers Link to comment Share on other sites More sharing options...
