BODY:JL61
BUILD: 09/21/89
SELLING DEALER: THOMPSON'S CHRY-JEEP
PLACERVILLE, CA
*X1 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ALA
BCYP 95 AMP BATTERY CBAP STRAIGHT BACK BENCH SEAT CKJP BLACK VINYL FLOOR COVERING
DBBC ALL MANUAL TRANSMISSIONS DCK DESCRIPTION NOT AVAILABLE EAAC ALL ENGINES
EAFC ENGINE EPD DESCRIPTION NOT AVAILABLE GRVP LEFT MANUAL MIRROR
HAA AIR CONDITIONING MDAP FRONT LICENSE PLATE BRACKET NAE CALIFORNIA EMISSIONS
NMCP HEAVY DUTY ENGINE COOLING PW7 BRIGHT WHITE CLEAR COAT SBA POWER STEERING
TAAC ALL TIRES TNCA P195/65R15 BSW AS TOURING TIRES WLYC ALL STEEL WHEELS
YGEA 5 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z64P LEFT FRONT GROUP XIII
Z82P RIGHT FRONT SPRING GROUP XI
APAS MONOTONE PAINT BAQS 115 AMP ALTERNATOR BGAS POWER FRONT DISC/REAR DRUM BRAKES
CSRS PASSENGER ASSIST HANDLES CUMS MINI FLOOR CONSOLE DHNS COMMAND-TRAC PART TIME 4WD SYSTEM
DJHS 230MM FRONT AXLE DMDS 3.55 REAR AXLE RATIO DRJS DANA 35 REAR AXLE
GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS
GEHS FIXED DOOR VENT GLASS GNAS REAR VIEW DAY/NIGHT MIRROR GUAS OPEN
JAZS DO NOT USE - SEE JP, KA CLASSES JCAS 85 MPH PRIMARY SPEEDOMETER KDBS STRIPE/BADGE/MOLDING
K3ZS STRIPE/BADGE/MOLDING/COLOR LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING
LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MFFS BLACK GRILLE
MHBS   MMCS   MMGS BELT MOLDINGS
MMJS MOLDED-IN-COLOR FENDER FLARES NBKS EVAP CONTROL SYSTEM NF2S 18 GALLON FUEL TANK
QW7S BRIGHT WHITE CLEAR COAT RA8S DELETE RADIO SCBS STEERING WHL
SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBCS COMPACT SPARE TIRE
TBMS TIRE CARRIER WINCH WJKS 15X6.0 STYLED STEEL WHEELS WMCS OPEN
XBSS PICKUP BOX YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z5AS GVW/PAYLOAD RATING
1AAS U.S. DEALER RETAIL 173S ZONE 73-SAN FRANCISCO 4AFS
