JimManche17 Posted March 1, 2024 Share Posted March 1, 2024 I have a 1988 2wd that I am looking to get a lift kit for. I really want to lift it 4.5". I was wondering if RUSTY'S MJ COMANCHE 4.5" SPRING PACK KIT would do the job or if anyone else has done this for a 2wd. https://www.rustysoffroad.com/collections/mj-comanche-86-93-suspension-systems/products/rustys-mj-comanche-4-5-spring-pack-kit?variant=39434915577952 Link to comment Share on other sites More sharing options...
gogmorgo Posted March 1, 2024 Share Posted March 1, 2024 Because the 2wd sits ~1” lower you might find more lift than you expect. I looked at the Rusty’s springs briefly but reviews are pretty hit or miss. For everyone who says they don’t have problems there’s someone who had major problems, and getting any sort of fix from Rusty’s doesn’t seem easy. Seemed like too much of a risk especially considering I’d be shipping it internationally. Link to comment Share on other sites More sharing options...
OldSch88L Posted March 5, 2024 Share Posted March 5, 2024 I bought them a bit over a year ago. From all the old posts and reviews I've read, the original version of those leafs really seemed bad. The ones I bought were the new generation I guess; Rusty's went to another subcontractor and they are now made in Canada. They're also painted now. They're a bit fiddly to install given their extreme arching, but I'm overall pretty satified by the quality, and they ride real nice. Be aware that out of the box on my truck at least ( ex-2WD 4-banger, 6 foot bed converted to 4x4) I had way more than 4.5 inches of lift, and had to put my spare tire back under the truck to add weight to try to match my Rubicon Express 4.5" front springs. It kinda worked, but I still have a slight rake, similar to stock. I'm leaving it alone for now, as I expect that the leafs may settle down over time. Link to comment Share on other sites More sharing options...
gogmorgo Posted March 5, 2024 Share Posted March 5, 2024 This thread was a big influence for my decision. I talked to a local spring shop and had a pair of leaves built. It wasn’t necessarily the cheapest option but shipping would’ve been brutal. Link to comment Share on other sites More sharing options...
OldSch88L Posted March 5, 2024 Share Posted March 5, 2024 If this can help for reference, these are my shackle angles right after I finished my install. Like I said, I put my spare back in, had the leafs and shackles bolted loosely, then had a "husky" friend (250lbs maybe) stand in the bed while I tightened everything up. When the leafs will show signs of relaxing, I'll loosen the bolts and tighten them with just the truck's weight. Link to comment Share on other sites More sharing options...
