94 Cherokee - what all could I use?
If I bought a 94 Cherokee for parts to use in my 2wd Comanche, what all could I use out of it? Basically everything except the suspension unless I mod the perches on the rear right?
What engines/transmissions are we talking about here with the 2 Jeeps? Year of your truck?
I have 2.5 engine in the 88 Comanche, and there is a 4.0 in the Cherokee. I already have a spare AX-15 and 231 sitting around as well. The 2.5 in the Comanche isn't a problem, as it's from a 93 or 94 YJ, so it runs really strong.
How much of a project are you looking for? You can't swap much in the way of individual parts in the drivetrain (2.5 and 4.0 don't share trannys and the t-cases should have different input spline counts), but you could swap over the entire thing including engine wiring harness and dash.
Mainly what I was looking for was the 4wd.
As for the 2.5 to the AX-15, I was searching for a Dakota bellhousing for that project. Might just do that in the Willys anyway.
Got it. Well, if you're just looking for a front axle, I personally wouldn't buy that particular Jeep. The gear ratio is only 3.55 if it's an auto and 3.07 if it's a stick. I'd keep looking for a 4.10 gear set if the 2.5L is to be retained.
:redX: The 2WD 2.5L MJs had 3.55 gears if they were 4-speeds.
