Idle/Stalling Issue Troubleshooting - Distributor Question
My jeep is an 89 2.5 TBI. It wants to stall real bad on start up and the problem has gotten worse to the point where it’s undriveable. So far, as per forum suggestion I have:
Cleaned throttle body
Replaced and adjusted IAC
Fixed every vacuum leak I could find
Tightened intake manifold bolts past factory torque spec
Replaced O2 sensor
I have a new TPS in the mail, will be putting it in tomorrow. I’m thinking about the distributor/new plugs (although the plugs look fine) but can‘t seem to find a distributor for my year and engine. Will a distributor for a 91 cherokee work? Does anyone have part number for an 89 2.5?
Thanks in advance.
We don’t have an IAC. We have an ISA that’s in front of the throttle body that requires specific adjustment procedure than the 4.0L IAC.
I can get you a part number for the distributor this evening. I don’t think it’s similar to the HO years.
Right yeah meant ISA. I have it set up such that it gently makes contact with the throttle arm. For a few months it worked fine this way. Can you point me in the right direction for setting it up properly?
Straight from the 2.5L AMC TBI book
As for the other part, I would get a hose that will fit snuggly over that and join the two pieces together. You will need that together or you will end up with a high idle after the ISA adjustment. The ISA bolt is supposed to make contact with the throttle plate, the ECU uses the ISA to adjust the idle speed.
