Disc brakes for 8.25
Need some help for rear discs on my 8.25. Currently running the grand Cherokee disc brake upgrade and while I love it, I'd really like to get a wilwood set up to match the front. They offer a kit for the d35 and the 8 3/4. I know the disc set up off the grand Cherokee is a d35 so in my head the one from Wildwood should work. Also apparently 8 1/4 and 8 3/4 brakes are interchangeable so that also should work with one of their kits. I'm I missing anything why this wouldn't work?
My experience with Wildwood brakes is there are just a handful of different calipers with a massive pile of adapters to mount them to every application imaginable.
It sounds alike you've got it thought out correctly.  I'd recommend fitting a caliper before opening all of your boxes and just make sure it will all bolt up and fit over the rotor correctly.
