Spinnakerblue89 Posted January 3, 2024 Author Share Posted January 3, 2024 So I just returned from vacation- thanks to everyone who provided input. It sounds to me like what I have put in will work okay, is that a correct assessment? I took the time to refresh the grounds diligently. Scraped paint, cleaned surfaces, I even replaced the eyelets on the ends of the grounds as the previous were getting oxidized and I know the grounds are not to be taken lightly on these suckers. I mean everything works fine, I suppose I'm just used to different outputs from the light assemblies on other vehicles. Heh? My ZJ and MJ are both similar now that I've compared the two. My Discovery 2 is also different as is my Ranger. The more ya know. Link to comment Share on other sites More sharing options...
Mark Serva Posted January 24, 2024 Share Posted January 24, 2024 I haven't had much luck with LEDs. I have found some don't actuate a blinker/4 way relay so one needs to get relay for LEDs. Some require 2 or 3 pin and some have a grounding wire. All kind of a hassle. Then, of course, I figured out that although LED themselves last 20 to 30,000 hours, the little electronic circuit that runs them is lucky to run as long as a regular GE or Philps incandescent, stock bulb. And, since most of this stuff comes out of China one has to deal with what they should say on their packages: China puts the C in Cuality! I'm going to use up my LEDs, doesn't take long, and go back to incandescent. Keep Jeepin on! Link to comment Share on other sites More sharing options...
