MississippiComanche Posted November 17, 2023 Share Posted November 17, 2023 Having a tough time finding this. Found the one for the 4.0....but can't find the one for the 2.5L Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 17, 2023 Share Posted November 17, 2023 Which tube? Front one to the air box or the rear to the throttle body base? Either way no one is making new ones. Link to comment Share on other sites More sharing options...
MississippiComanche Posted November 17, 2023 Author Share Posted November 17, 2023 the one in the rear. Right now it has a homemade rig with a hose as a grommet with a pcv valve pushed in haha. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 17, 2023 Share Posted November 17, 2023 This is what it looks like. The 4.0L if I recall has something really damn close and if it is, you’ll just need to modify the length and put about 2-2 1/2” of hose on the end to connect to the base of the TB. Link to comment Share on other sites More sharing options...
MississippiComanche Posted November 17, 2023 Author Share Posted November 17, 2023 so what I found on the Mopar site diagram were these grommets for front and back....and this elbow and pcv valve for the front and back. I already ordered and shipped them to my house. Seem to fit snug on the new valve cover but not sure if I should use or not Grommets: https://www.autozone.com/emission-control-and-exhaust/pcv-valve-grommet/p/dorman-pcv-valve-grommet-42059/730537_0_0 Elbow (Front) https://www.amazon.com/Crown-Automotive-J3236685-Valve-Elbow/dp/B00BA770IM PCV Valve (Back) https://www.amazon.com/Standard-Motor-Products-PCV-Valve/dp/B000C842AO Link to comment Share on other sites More sharing options...
MississippiComanche Posted November 17, 2023 Author Share Posted November 17, 2023 The one for the 4.0 is at Napa. Part #7151365 https://www.napaonline.com/en/p/NOE7151365 Do you think I should just order this a cut the hose shorter to fit? Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 17, 2023 Share Posted November 17, 2023 56 minutes ago, MississippiComanche said: The one for the 4.0 is at Napa. Part #7151365 https://www.napaonline.com/en/p/NOE7151365 Do you think I should just order this a cut the hose shorter to fit? This should work. Just cut to fit. As for the others, the bigger opening grommets are meant for 84-86 years both carbed and TBI. Mine is 88 and I think I remember yours being an 87 unless you have a weird one where AMC threw and 86 engine and TBI set up as a "use what we have left" deal. For the front elbow, if yours doesnt have the original I guess something could be set up using that elbow and a hose to connect the two. This is kinda why I tell people to grab 2.5L stuff when they see it. I only have one spare of each of these lines for myself. No one makes the vac lines for this engine. Done ranting. Link to comment Share on other sites More sharing options...
