1989 MJ Turn Signal Sound Volume
Howdy folks. I have a 1989 MJ and my turn signals work just fine, reasonable speed and all, but the ticking sound associated with the turn signal is quiet in the cab and I would like to be able to hear it better rather than just seeing the indicator lights on the dash. Is there a louder flasher relay I could install?
I installed a heavy duty one typically used for hazards onto my main flasher spot, it flashes about the same speed with a little louder more satisfying click, and works well with trailers
