Purchased this as a parts truck in October of 2016 to pull
the HO for a swap into my other Mj. After investigation I
decided it was not worth the effort and sold it to a gentle-
man from PA to turn into a buggy. Had about 225,000
when it finally left.
BODY: JL62
BUILD: 02/18/91
SELLING DELAER: BUCKHANNON JEEP-EAGLE
BUCKHANNON, WV
*C1 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ALA
ALK   CBAP STRAIGHT BACK BENCH SEAT CKJP BLACK VINYL FLOOR COVERING
DBBC ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION ERH 4.0L I6 POWER TECH ENGINE
GRVP LEFT MANUAL MIRROR JJAA CIGAR LIGHTER MBJA BLACK FRONT BUMPER
PE9 DESCRIPTION NOT AVAILABLE TPF P205/75R15 BSW ALL SEASON TIRES TZHP MICHELIN BRAND TIRES
WLYC ALL STEEL WHEELS YEP MANUF STATEMENT OF ORIGIN YGEA 5 ADDITIONAL GALLONS OF GAS
Z01P REAR SPRING GROUP I Z65P LEFT FRONT GROUP XIV Z84P RIGHT FRONT SPRING GROUP XIII
3VQA CUSTOMER PREFERRED DISCOUNT
APAS MONOTONE PAINT BAPS 75 AMP ALTERNATOR BCCS MAINT. FREE BATTERY
BGAS POWER FRONT DISC/REAR DRUM BRAKES CUMS MINI FLOOR CONSOLE DHNS COMMAND-TRAC PART TIME 4WD SYSTEM
DJHS 230MM FRONT AXLE DMMS 3.07 REAR AXLE RATIO DRJS DANA 35 REAR AXLE
GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS
GEHS FIXED DOOR VENT GLASS GUAS OPEN HCDS DO NOT USE - SEE HCA
JAZS DO NOT USE - SEE JP, KA CLASSES JCAS 85 MPH PRIMARY SPEEDOMETER KWWS DESCRIPTION NOT AVAILABLE
K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS SHIFT INDICATOR WARNING LAMP LBCS GLOVE BOX LAMP
LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MFFS BLACK GRILLE
MHBS FENDER FLARES MMCS   MMGS BELT MOLDINGS
MMJS MOLDED-IN-COLOR FENDER FLARES NAAS FEDERAL EMISSIONS NBKS EVAP CONTROL SYSTEM
NF5S 23 GALLON FUEL TANK QE9S DESCRIPTION NOT AVAILABLE RA8S DELETE RADIO
SBAS POWER STEERING SCES STEERING WHEEL SFAS STANDARD DUTY FRONT SHOCK ABSORBERS
SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBCS COMPACT SPARE TIRE TBMS TIRE CARRIER WINCH
WJKS 15X6.0 STYLED STEEL WHEELS XBSS PICKUP BOX YAAS BUILD TO U.S. MKT. SPECIFICATIONS
Z5AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 135S ZONE 35-WASHINGTON
