Dandxj Posted October 18, 2023 Share Posted October 18, 2023 92 MJ I am attempting to repair a few terminals in the fuse block. Is there a special tool or technique for attaching the wires to the new buss bar terminals? The crimp tool I have is fine for single terminals but will not work on the 2,3,4 gang buss bars. I could use needle nose pliers but the crimps would probably be sloppy and not as secure as an OE crimp. Thanks Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 18, 2023 Share Posted October 18, 2023 Are you referring to the connections in the power distribution center by the radiator overflow bottle? If so, most of those are a roll over style crimper. I bought a ratcheting crimper with interchangeable dies but they are pricey. If it’s just a small job, the Painless 70900 crimper works well enough. There are other members here though that can probably suggest better options. Can you post of picture of the connector you’re trying to crimp to verify the type needed? Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted October 18, 2023 Share Posted October 18, 2023 I think he means these guys, but idk what crimper is narrow enough to get in there. You only need to squeeze one of them though. That’s what the buss is for. Solder would work. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 18, 2023 Share Posted October 18, 2023 47 minutes ago, GonzoTheGreat said: I think he means these guys, but idk what crimper is narrow enough to get in there. You only need to squeeze one of them though. That’s what the buss is for. Solder would work. Those are roll over style crimps. Grab that painless 70900 tool. Decent tool for the price and will take care of those for you. https://www.painlessperformance.com/wc/70900 Link to comment Share on other sites More sharing options...
Dandxj Posted October 19, 2023 Author Share Posted October 19, 2023 I am repairing the fuse block under the dash. Yes, the ones pointed out by GonzoTheGreat are the terminals in question. I have a similar tool as pictured which works great for a single wire terminal but will not work for the multiple terminal buss strip - unless there is trick I am not seeing. I believe I need to reattach all the wires presently used in the fuse block. Link to comment Share on other sites More sharing options...
