yungupgrade Posted October 9, 2023 Share Posted October 9, 2023 Does anyone know what gauge the wire going from the starter solenoid to the wiring harness is? And what type of connector these two female ends are called? Link to comment Share on other sites More sharing options...
pizzaman09 Posted October 10, 2023 Share Posted October 10, 2023 Those female connectors are just 1/4" spade connectors. Any old spade connectors will do as the OEM ones are not even sealed. The square housing ones on the Comanche seem to be pretty common in period, I've seen similar connectors on an 80s Toyota and on a 90s BMW. Link to comment Share on other sites More sharing options...
schardein Posted October 10, 2023 Share Posted October 10, 2023 If you are referring to your photo, that isn't a starter solenoid. That is a ballast resistor. The wires look like 14 or 16 gauge. The terminals are commonly referred to as Packard 56 terminals. I have new, original terminals available if you need some. I also have those single terminal connectors in the picture. https://www.ebay.com/itm/334313756275?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bpFa1QANQb2&sssrc=2380676&ssuid=bpFa1QANQb2&widget_ver=artemis&media=COPY https://www.ebay.com/itm/235169838739?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bpFa1QANQb2&sssrc=2380676&ssuid=bpFa1QANQb2&widget_ver=artemis&media=COPY Link to comment Share on other sites More sharing options...
yungupgrade Posted October 10, 2023 Author Share Posted October 10, 2023 14 hours ago, schardein said: If you are referring to your photo, that isn't a starter solenoid. That is a ballast resistor. The wires look like 14 or 16 gauge. The terminals are commonly referred to as Packard 56 terminals. I have new, original terminals available if you need some. I also have those single terminal connectors in the picture. https://www.ebay.com/itm/334313756275?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bpFa1QANQb2&sssrc=2380676&ssuid=bpFa1QANQb2&widget_ver=artemis&media=COPY https://www.ebay.com/itm/235169838739?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bpFa1QANQb2&sssrc=2380676&ssuid=bpFa1QANQb2&widget_ver=artemis&media=COPY I should have clarified. Those connectors are just similar to the ones that came off of the wire that ran to the starter solenoid, I just did not have a picture. I couldn't find any info about the specific gauge wire for the solenoid connection. I need to solder a new one as the one from my old starter was crimp connected. Link to comment Share on other sites More sharing options...
schardein Posted October 10, 2023 Share Posted October 10, 2023 30 minutes ago, yungupgrade said: I should have clarified. Those connectors are just similar to the ones that came off of the wire that ran to the starter solenoid, I just did not have a picture. I couldn't find any info about the specific gauge wire for the solenoid connection. I need to solder a new one as the one from my old starter was crimp connected. This is a screenshot of the starter circuit from the 1988 Comanche electrical troubleshooting manual. The starter solenoid wire is 14 gauge. Link to comment Share on other sites More sharing options...
yungupgrade Posted October 10, 2023 Author Share Posted October 10, 2023 4 hours ago, schardein said: This is a screenshot of the starter circuit from the 1988 Comanche electrical troubleshooting manual. The starter solenoid wire is 14 gauge. Thank you Link to comment Share on other sites More sharing options...
