Tyler_Smith_28 Posted September 25, 2023 Share Posted September 25, 2023 Hello, I have an intermittent problem with my jeep comanche where it will only start in neutral. The ignition will not even turn over when in park sometimes. I'm looking for a solution to this problem. Thank you, Tyler Link to comment Share on other sites More sharing options...
The86manche Posted September 25, 2023 Share Posted September 25, 2023 Sounds like dirty or our of adjustment neutral safety switch. You can remove and clean them up Link to comment Share on other sites More sharing options...
Tyler_Smith_28 Posted September 25, 2023 Author Share Posted September 25, 2023 Thanks! You're a great help! Link to comment Share on other sites More sharing options...
gogmorgo Posted September 26, 2023 Share Posted September 26, 2023 http://gojeep.willyshotrod.com/HowtoNSSrebuild.htm I'll second the neutral safety switch. I bet your reverse lights are also intermittent. When I cleaned mine out, I ran a bead of rtv around the gasket for extra protection. Always use protection. Link to comment Share on other sites More sharing options...
