Warren99 Posted September 19, 2023 Share Posted September 19, 2023 So my lines are cracked and leaking now. My truck is an 89, but I swapped a pump from a 96 cherokee a long time ago. When I did, I used one of the lines from the Cherokee, and one line from my truck. My question is can I just order 2 new lines for a 96 cherokee and they both fit, or is the layout or steering box somehow different on a 89? Link to comment Share on other sites More sharing options...
AZJeff Posted September 19, 2023 Share Posted September 19, 2023 43 minutes ago, Warren99 said: So my lines are cracked and leaking now. My truck is an 89, but I swapped a pump from a 96 cherokee a long time ago. When I did, I used one of the lines from the Cherokee, and one line from my truck. My question is can I just order 2 new lines for a 96 cherokee and they both fit, or is the layout or steering box somehow different on a 89? Order the ones for the 96 XJ, and they will fit fine on your MJ. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted September 19, 2023 Share Posted September 19, 2023 I just flushed my power steering fluid. Quick blurb about the power steering fluid in case you are interested: The 1988 service manual states the Power Steering fluid for the 88 steering box is AMC# 8993342 Internet says the equivalent mopar# is MS-5931. MS-5931 = gm 9985010. It is clear in appearance, slightly amber on a paper towel. Valvoline 602241 meets gm 9985010 spec. I called up Keene, NH Jeep. mopar# 68218064ac is the current version of power steering fluid for cherokee / comanche. It is called "power steering +4" It contains no ATF. I asked them specifically. You can still get 68218064ac today. I settled on the valvoline 602241. It's been working great so far. I needed 2 quarts to properly flush my power steering pump. Link to comment Share on other sites More sharing options...
