Tree Posted September 10, 2023 Posted September 10, 2023 1991,Jeep,Comanche, Base? Engine: I6 4.0 L (242 CID) Transmission: AX-15 10in/23out (Spline)(5 speed Manual) Gear ratios 1st-3.83 2nd-2.33 3rd-1.44 4th-1.00 5th-0.79 (3.3 Quarts 75w-90 GL4) Transfer Case: NP231 Command-Trac (Two-Speed 2.72:1) Chain Driven (2 Quart ATF-4) Front Axle: Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 86-92 (all axles are vacuum disconnect, and have 5-260x u-joints) Rear Axle: Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 89-92 Wheelbase : Short Bed 4wd=112.9 Build Date: 1/91 Current Location: Northern California Status: On the road Current Owner: Girlfriend,
jdog Posted September 15, 2023 Posted September 15, 2023 BODY: MJJL61 BUILD: 01/30/1991 SELLING DEALER: NEAL POPE CHRYSLER-PLYMOUTH-JEEP ATLANTA, GA *D4 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ALA ALK BAFP 130 AMP ALTERNATOR BCYP 95 AMP BATTERY CBAP STRAIGHT BACK BENCH SEAT CKJP BLACK VINYL FLOOR COVERING DBBC ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION ERH 4.0L I6 POWER TECH ENGINE GRVP LEFT MANUAL MIRROR HAA AIR CONDITIONING JJAA CIGAR LIGHTER MBJA FRONT BUMPER PE4 Colorado Red SBAA POWER STEERING TMW TIRES TZHP MICHELIN BRAND TIRES WJN 15 ALUMINUM WHEELS WLZC ALL ALUMINUM WHEELS YGEA 5 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z65P LEFT FRONT GROUP XIV Z82P RIGHT FRONT SPRING GROUP XI 3VQA CUSTOMER PREFERRED DISCOUNT APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES CUMS MINI FLOOR CONSOLE DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS 230MM FRONT AXLE DMMS 3.07 REAR AXLE RATIO DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GEHS FIXED DOOR VENT GLASS GUAS OPEN JAZS DO NOT USE - SEE JP, KA CLASSES JCAS 85 MPH PRIMARY SPEEDOMETER KDNS DESCRIPTION NOT AVAILABLE KWSS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS SHIFT INDICATOR WARNING LAMP LBCS GLOVE BOX LAMP LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MFFS BLACK GRILLE MHBS Body Color Fender Flares MMCS MMGS BELT MOLDINGS MMJS MOLDED-IN-COLOR FENDER FLARES NAAS FEDERAL EMISSIONS NBKS EVAP CONTROL SYSTEM NF2S 18 GALLON FUEL TANK QE4S Colorado Red RA8S DELETE RADIO SCES STEERING WHEEL SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBCS COMPACT SPARE TIRE TBMS TIRE CARRIER WINCH XBSS PICKUP BOX YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z5AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 161S ZONE 61-ATLANTA
