1991,Jeep,Comanche, Base?
Engine: I6 4.0 L (242 CID)
Transmission: AX-15 10in/23out (Spline)(5 speed Manual) Gear ratios 1st-3.83 2nd-2.33 3rd-1.44 4th-1.00 5th-0.79 (3.3 Quarts 75w-90 GL4)
Transfer Case: NP231 Command-Trac (Two-Speed 2.72:1) Chain Driven (2 Quart ATF-4)
Front Axle: Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 86-92 (all axles are vacuum disconnect, and have 5-260x u-joints)
Rear Axle: Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 89-92
Wheelbase : Short Bed 4wd=112.9
Build Date: 1/91
Current Location: Northern California
Status: On the road
Current Owner: Girlfriend,
