Tree
Tree's Achievements
  1. Wow this has made a damn good turn around. Good job!
  2. Love being a part of this community, the vin registry is a godsend. It gave me some insight on how much the previous owner was a story teller on the truck, but also verified what was true.
  3. Yeah I was referring to the plastic water shield. Thank you Pete and ghetdjc320. Not afraid of making my own, just was curious if any companies made a replacement. I have a fox body mustang and damn near everything on those reproduce :/
  4. In the process of doing a restoration to the doors and was curious is anyone has any information on the inner door plastic. Dose anyone offer the weather seal? Or dose anyone have a solution?
  5. Tree
    1J7FJ26SXML571959
    1991,Jeep,Comanche, Base? Engine: I6 4.0 L (242 CID) Transmission: AX-15 10in/23out (Spline)(5 speed Manual) Gear ratios 1st-3.83 2nd-2.33 3rd-1.44 4th-1.00 5th-0.79 (3.3 Quarts 75w-90 GL4) Transfer Case: NP231 Command-Trac (Two-Speed 2.72:1) Chain Driven (2 Quart ATF-4) Front Axle: Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 86-92 (all axles are vacuum disconnect, and have 5-260x u-joints) Rear Axle: Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 89-92 Wheelbase : Short Bed 4wd=112.9 Build Date: 1/91 Current Location: Northern California Status: On the road Current Owner: Girlfriend,
