Whitaker717 Posted July 18, 2023 Share Posted July 18, 2023 Hi guys I am about to replace my heater core and evap coil. I really have no idea where to get them. I have an 87 4.0. Any links or recommendations would be appreciated. Link to comment Share on other sites More sharing options...
Pete M Posted July 19, 2023 Share Posted July 19, 2023 got mine on amazon. any parts store can get them too. if you're digging that deep into the truck, make sure you have a list of everything you can accomplish on the way in. especially with water intrusion spots like the antenna grommet and hvac seals. Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 19, 2023 Author Share Posted July 19, 2023 12 hours ago, Pete M said: got mine on amazon. any parts store can get them too. if you're digging that deep into the truck, make sure you have a list of everything you can accomplish on the way in. especially with water intrusion spots like the antenna grommet and hvac seals. You have links to any of that stuff Pete? Link to comment Share on other sites More sharing options...
Pete M Posted July 19, 2023 Share Posted July 19, 2023 note that the evap ports are in a slightly different orientation which meant I had to custom make the foam seal. I could not locate one that had the exact same locations as the 88 in my driveway. but the old foam was trash and leaky so it was going to happen anyways. https://www.amazon.com/Evaporator-Core-Compatible-Jeep/dp/B09S41YQ8Y https://www.amazon.com/Spectra-Premium-93024-Heater-Core/dp/B000C7TSNG/ Link to comment Share on other sites More sharing options...
