So the other day i started joe dirt n it cranked n cranked then blew a puff of smoke out my snorkel. I tried again n it ran a lil rough. Next day i went out n cranked it n fired right up but its idling around a grand. As it got hotter it starts idling higher around 11-1200. Any ideas? Another thing i noticed was the plug all the way to the right on my icm has no plug in it. Any help would be appreciated. Thanks
any work done recently?  can you share a photo of the plug?  have you tested the TPS?  checked for vacuum leaks?
I haven't messed with it yet. Just  figured id ask here 1st. I have my father-in-law funeral today so tomorrow ill add pics. The wiring is a nightmare under my hood.
I found and repaired some vacuum leaks idle is fine. I'm having an intermittent starting issue now. Smh, it cranks n cranks with no joy then ill crank n it fires right up.
