Jeeper1093 Posted June 6, 2023 Posted June 6, 2023 I am looking for a vacuum fitting for my 86 4 cylinder Comanche. I am loosing vacuum around the 4 line fitting going to the throttle body. I have no idea what this part is called so I am having trouble finding one locally. If any knows what it's called or has info on how to get one, your help would be greatly appreciated. I have a rough idle and I believe that this leak may be causing it. Thank you in advance for any help.
eaglescout526 Posted June 6, 2023 Posted June 6, 2023 There’s a bulletin in one of my service manual books that says to get rid of that block and just use vac lines to the throttle body.
Jeeper1093 Posted June 7, 2023 Author Posted June 7, 2023 Fantastic. That's simple enough. Thanks for the help!
