So I just replaced my injectors to the volvo ones everyone talks about but now there's no fuel pressure on the line it has a hard time starting and it's throwing both loop fault lean and rich. Any ideas on what it could be
22 minutes ago, cruiser54 said:
Where did you get those injectors?
Did you dislodge a connector on the fuel pump ballast resistor?
Ebay with the part number and I don't think I did. I didn't touch the ballast resistor
There are a ton of crappy injectors coming off ebay. Chinese knock offs.
New plan now is to contact Trevor for rebuilt and tested injectors.
trevor.skankfootracing@gmail.com
