91Pioneer Posted May 22, 2023 Posted May 22, 2023 I have the header panel off my front end to hardwire DRLs and put the replacement "upgrade" headlight harness in. So there is 12V battery power at the red wire on the 10 pin harness. I am struggling a bit with the wiring diagram. Does anyone know if the 12V constant wire is fed through a fuse or relay in the fuse box? I'm not all sure where that red wire comes from and what else it might power, however it appears that 12V battery wire is used by the fog light relay. This is for a 1989 MJ. I am possibly going to tap that wire for the DRL relay constant power.
Ωhm Posted May 22, 2023 Posted May 22, 2023 11 minutes ago, 91Pioneer said: So there is 12V battery power at the red wire on the 10 pin harness Is this C102_6? If it is, then C102_6 uses Fusible Link H (Hot at all times).
91Pioneer Posted May 22, 2023 Author Posted May 22, 2023 Yes, C102 connector, pin #6. Where is the fusible link located? Is it connected to the starter relay beside the battery? I noticed some wires coming off there. And do you know the capacity of the stock fusible link?
Ωhm Posted May 22, 2023 Posted May 22, 2023 2 minutes ago, 91Pioneer said: Where is the fusible link located? Is it connected to the starter relay beside the battery? Yes Battery Terminal with all Fusible links. 3 minutes ago, 91Pioneer said: And do you know the capacity of the stock fusible link? No I don't. Something with gauge size.
