I recently bought the JPSU-6 MTS replacement sending unit as my fuel pump still worked and I thought I could swap it in. However when I finally went to swap it in, it doesn't seem to fit in the rubber mount that came with the kit. I read that I should get a Bosch unit off roackauto but it doesn't seem like they sell one anymore. Is there a specific brand I should buy that is compatible with the MTS unit? This one looks like it should work but I'm not sure: https://www.rockauto.com/en/moreinfo.php?pk=11961517&cc=1181584&pt=6256&jsn=853.
or you could just use hose clamps to secure it to the sending unit assembly as shown in the picture and save some $$ for other things
Ended up using cable ties to secure the pump. The pump contacts the gauge reader ground. Not sure if that will be a problem down the line but there's no great way to get it to stay. The mounting system kinda sucks for 87 dollars.
