Parking brake pedal
I'm missing the return spring for my parking brake pedal. Other than pics I have no idea what it looks like. Does anyone have the dimensions or a number for a part that will interchange?
I doubt that spring was ever available as a replacement part unto itself.
You can probably create a functional replacement from some stock spring purchased at a decent hardware store.  You might have to cut it to length and bend the ends to make the appropriate "tails" on the spring.
I appreciate that. I found the broken spring under the edge of the carpet and I'm going to try and make it work. Other wise we have a Napa the road. I was hoping someone had found an aftermarket part.
