Dale Colton Posted May 8, 2023 Share Posted May 8, 2023 (edited) I just purchased A 1986 comanche with the Renault diesel engine, the truck has factory A/C. The system is empty. I went to hook up the gauge set and can not locate the high presure service port. The low side is on the line about 6 inches from the compressor. I have followed the high presure line from one end to the other including pulling the grill out to get a better look at the receiver dryer. The dryer does have a sight glass and limit switch. I do have the factory M.R.277 repair manual, nothing on port location in there. Thanks for any help. Edited May 8, 2023 by Dale Colton Add photos Link to comment Share on other sites More sharing options...
jdog Posted May 8, 2023 Share Posted May 8, 2023 I think it's on the compressor itself Link to comment Share on other sites More sharing options...
Dale Colton Posted May 8, 2023 Author Share Posted May 8, 2023 I looked the compressor over very carfully with no luck. I even looked where it might have been and was broken off. no sign of it. Link to comment Share on other sites More sharing options...
Ωhm Posted May 8, 2023 Share Posted May 8, 2023 From the Motor Manual Guy: Air conditioning system The air conditioning system consists of a condenser mounted in front of the radiator, an evaporator mounted adjacent to the heater core, a compressor mounted on the engine, a receiver-drier which contains a high pressure relief valve and the plumbing connecting all of the above components. Link to comment Share on other sites More sharing options...
