Kikapoo Posted May 2, 2023 Share Posted May 2, 2023 Hello, I was wondering if anyone can answer a question. I have 87 comanche 2.5l automatic transmission . I was wondering if I can replace my TBi injector with a Gm tbi injector? Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 2, 2023 Share Posted May 2, 2023 Yes. They’re the same injector. Link to comment Share on other sites More sharing options...
Gojira94 Posted May 2, 2023 Share Posted May 2, 2023 I admittedly haven't looked up the specs on the factory 2.5 injector and don't know the operating pressure but here's a really good resource: http://www.gearhead-efi.com/Fuel-Injection/showthread.php?81-GM-TBI-Injector-size-color-and-part-numbers Important to remember that the GM injectors ran at 12-13psi, except for the 94-95 454s which ran smaller ones at higher pressure. 242ci x .667 = 161.414ci (2.5l displacement in c.i.) Chevy 305ci / 2 = 152.5ci (similar displacement, 305 has 2x 54#/hr injectors) if fuel pressure is in the same ballpark, 12-15psi then yeah. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 2, 2023 Share Posted May 2, 2023 11 minutes ago, Gojira94 said: if fuel pressure is in the same ballpark, 12-15psi then yeah Fuel pressure at the throttle body is 15psi max. So he will be fine with a GM one. I'm assuming the PO is going GM probably because they have a line on some cheap ones or aftermarket is cheaper for GM Link to comment Share on other sites More sharing options...
Gojira94 Posted May 3, 2023 Share Posted May 3, 2023 6 hours ago, eaglescout526 said: I'm assuming the PO is going GM probably because they have a line on some cheap ones or aftermarket is cheaper for GM Definitely. Several years ago I got a pair of rebuilt 80pph for my C1500. Running them vacuum referenced at 109pph@23psi WOT/16psi idle. Very nice conical spray pattern with the Rochesters. Link to comment Share on other sites More sharing options...
