xxmetal Posted March 23, 2023 Share Posted March 23, 2023 Howdy all! Hope y'all might be able to help orient me with this *nearly* catastrophic electrical failure I am having. Just bought my '86 on Sunday, and began experiencing issues with the electronics on Monday night. No issues the whole time I was test driving, or driving the two hours home. Since then, this issue has been presenting itself maybe 80% of the time I have spent driving. Complete loss of non-engine electrical systems. No radio, no lights (internal or external), no gauges, no heat/AC, no horn. But the car starts right up no problem, and continues to drive no problem. When running, battery measured at 14.2 V post to post, crossing off a battery/alternator problem. No blown fuses that I could find. When the issue somewhat corrects itself, I have seen 2 conditions: 1. Full system functionality. Everything works as it should 2. The radio and gauges turn on. If any other power is requested (turning on headlights/gauge lights, or turning on heat/AC) the whole system shuts down again Where should I start? I don't want to disturb the engine, it seems to be working perfectly. I have ordered the 1986 electrical manual from Ebay, so I probably won't be able to do any unassisted wire-chasing until it arrives. Is this a common issue? Thank you! Link to comment Share on other sites More sharing options...
cruiser54 Posted March 23, 2023 Share Posted March 23, 2023 Burned brown wire at ignition switch. Switch likely toast. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 23, 2023 Share Posted March 23, 2023 Grounds too! Check and clean all grounds. Chances are the original owner probably didn’t do a damn thing to them. Link to comment Share on other sites More sharing options...
